- 1 Aug 2017
Sweet!
Mine is being delivered within the next hour...looking forward to building this tonight![]()
Nice. Some pics would be great, interested to see what your build looks like.
Looks really nice. Your right about the depth, it's not until you see it next to a setup that you notice how little room it takes.
Just needs a RGB strip installed, no point having a window if you're not going to go all bling.![]()
Indeed there is not, I'm going to have to revisit the idea as I bought some Phanteks strips but because I have an older ITX Board it doesn't have the RGB header required to use them so will pick up some different ones![]()
There is an RGB control button on the chassis itself. You won't get the depth of control that you do using Asus Aura etc, but it's still good enough for most![]()
I'll tell you what though, the Silverstone SFX L series of PSU are a nightmare to fit in this thing...Looking good!
Basically with the cables connected they essentially hit right against the cable management tray meaning you can't feed the cables through as desired.
I had to work some through the rear of the case and back through the cable management tray which has made it slightly untidy unfortunately, but happy enough with the build still.
Word of warning for anyone who is building with that PSU.
Ok cool. I'll repostI find the Img tag dont work for me eiher....
