I could take it a step further and say complain at
http://www.anandtech.com/show/6396/the-vishera-review-amd-fx8350-fx8320-fx6300-and-fx4300-tested/6 this instead. Shows increased powerdraw over a 920 under load. My opinion was based on that.
Also most of the x58 boards that i have worked with are overvolting the cpu like crazy. Example my gigabyte x58-ud4p had the idea of running my 920 C1 at stock clocks at 1,31volts. The sabertooth im on now wants to give it 1,3volt. The lowest stable im been able to do has been 1,05volt so fare. My point is that i dont think this is something the reviewers take in to consideration when they power bench the systems. They most likely just plug the beast in measure and go on to the next cpu on their charts.
And even if when the dust settles it shows that the piledriver is a better at powerconsumption its not by much, but actually quite unimpressive considering the fact that its against (as you pointed out 32nm vs 45nm) a 4 year old chip.
Dont get me wrong here, i would love for the AMD CPUs to be better, i wouldnt even mind using one myself with its current performance if the power draw was a little better.
