Was hoping that would be the case when I stuck a 4070ti in but no such luck!
did you downgrade your GPU too?
I've got a 4090 but stuck a 4070ti in to rule out it being the GPU.did you downgrade your GPU too?
Ahh gotcha.I've got a 4090 but stuck a 4070ti in to rule out it being the GPU.
That's the one thing I haven't swapped out.Know we talked about it but did you ever get round to trying a different psu?
Would just be the motherboard then.I think it's worth a go, if not to rule another aspect out..
What does that leave after? Just the motherboard as only other component?
I think there are ways to track if you have the TPM stutter issue, without needing to buy one.I've read getting a TPM module that you actually stick in to the motherboard can help? Anyone else had any experience with this?
How so?I think there are ways to track if you have the TPM stutter issue, without needing to buy one.
I haven't looked at it, in awhile, but from what I can recall of the AMD fTPM issues, it spams the event log with errors and the stuttering tends to be intolerable, whereas what you're describing with the FPS drops is probably not the same.How so?
