Possible Radeon 390X / 390 and 380X Spec / Benchmark (do not hotlink images!!!!!!)
Status
Not open for further replies.
How many people who are debating in this thread are actually going to buy the Fury X ?
I'm debating on buying the fury but not the 4gb model, will be waiting for 8gb instead depending on price and performance obviously lol. Otherwise 980ti it will be!
Also @ greg sorry couldn't resist :P
I definitely won't be. In fact the only reason I've been posting in this thread is because I'm GPUless (thanks to OCUK and EVGA).
But now that I have been posting I'll follow the aftermath of the release. The build up has been so long that it's quite exciting to see what happens.
If the Fury had more than 4 GB VRAM I would have seriously considered it as a single GPU solution. Though it would also have to be noticeably faster than the Titan X.
Possibly me. It all depends on the performance and price. Plus how the release may affect the price of all the other cards. Definitely want a new card before the end of July though!
gpus only come in twos for me , so they need to display a major overhaul in multi GPU support , needs to be as fast as a 980ti and a good 50-75 quid cheaper and I'll be first to drop an order . Saying this I need to know that 4gb HBM is going to be used differently as it just isn't enough :(
Going to be interesting seeing how these stack up. 6GB/12GB's of GDDR5 vs a lesser amount of HBM at possibly twice the speed.
Is more always better? I mean would you pick a 4GB DDR3 card over a 2GB GDDR5 card? Because moarz ram ! Doubtful.
I am wandering if it will mean stutter when going from GPU to system but I'll hold judgement until you know we actually see the performance. HBM is an unknown quantity atm.
Only 3 days to go.
I'm bound to buy Fury. I said to myself long ago when I bought 7970, that I'll skip 200 series, just to buy 300 series. I gotta keep promise made to myself. Or else I'll never trust myself.
This is the big question, and the benchmarks will give us the answer. I suspect it will perform FAR better than people suspect though... more is certainly not always better. We'll just have to see what difference HBM makes.
You can't be that emphatic without seeing benchmarks surely? Would you ignore the Fury X if it came in cheaper than the 980Ti and trounced it (or equalled it) in all benchmarks... simply because the 980Ti has 2GB extra RAM?? That would make zero sense.
I'm eagerly waiting to see what happens with the benchmarks... should prove VERY interesting. :)
Status
