Tobago is rumoured to be a new GPU.
http://wccftech.com/amd-gpus-fiji-grenada-trinidad-tobago-unveiled-computex-2015/
The World is watching
AMD had better have something good in store
When in the God's name will we see what these cards look like?
I want to see if AMD have come up with some sort of monstrosity of a cooler!![]()
AMD Radeon R9 390/390X – Fiji Pro/Fiji XT graphics processing units featuring GCN 1.3 architecture with up to 4096 stream processors and 4096-bit interface to HBM memory. Price range: $649 and upwards.
AMD Radeon R9 380/380X – Grenada Pro/Grenada XT graphics processing units featuring GCN 1.2 or GCN 1.3 architecture with up to 2816 stream processors and 512-bit interface to GDDR5 memory. Price range: $249 – $299 – $329. Since “Grenada” GPU is basically a revamped “Hawaii”, it is possible that instead of making a new GPU, AMD will simply use the old one under a new moniker.
AMD Radeon R9 375X – Tonga XT graphics processing units featuring GCN 1.2 architecture with up to 2048 stream processors and 384-bit interface to GDDR5 memory. Price range: around $229.
AMD Radeon R9 375 – Tonga Pro graphics processing units featuring GCN 1.2 architecture with up to 1792 stream processors and 256-bit interface to GDDR5 memory. Price range: around $199.
AMD Radeon R9 370/370X – Trinidad Pro/Trinidad XT graphics processing units featuring GCN 1.3 architecture with up to 1536 stream processors and 256-bit interface to GDDR5 memory. Price range: $119 – $149.
So the 380x is basically a rebadged 290x![]()
from kit guru
380/x = 290/x
375x = 280 with more stream processors but less than a 290
370x = 285 x
Only the 390 is something genuinely new according to that which is a shame I hope it's good.
It was just forum chatter from some obscure German site, the tech sites published it as fact and now it's gospel for some reason.
The Chiphell benches have more credibility.
They will have to make two different chips if they have 8 and 4GB SKUs. They will want to do a 2nd salvage on the 390 parts that don't quite cut it.
So 380X could just as easily be 4GB HBM Fiji.
from kit guru
380/x = 290/x
370x = 285 x
Fiji XT and Fiji VR dual-chip
We have an update on AMD’s highly anticipated flagship GPU, codenamed Fiji.
There will be at least two Fiji cards, probably even more. The second revision of the GPU works a bit better and some of you might know that Fiji was supposed to come in Q1, but it was delayed for mid- 2015.
As far as our sources are aware, the launch date is in June or the last month of the second quarter. AMD should launch the Carrizo APU at Computex at some point after June 2nd, and we heard that Fiji might come a week or two later, if not at the same event.
from kit guru
380/x = 290/x
370x = 285 x
AMD Radeon R7 360X ‘Tobago’ GPU Spotted – Radeon 300 Series Begins AIB Seeding
Read more: http://wccftech.com/amd-radeon-r7-300-series-gpus-aib-seeding/#ixzz3XmwHVEvU
