Recurrect this:
2 x Seagate ST3250410AS 250GB Hard Drive @128kb
Looks a bit low....
You get 500Gb storage space after buying 2.5Tb of storage? Doesnt seem worth it to me.5x500gb in raid5
Just to be pedantic what you've described is RAID3 (dedicated parity disk), with RAID5 the parity is striped across all drives so in a 5 disk array each drive is 80% data and 20% parity. The advantage of striping the parity is that the RAID5 array is not limited by the write speed of a single drive in the way that RAID3 is. However to take advantage of this you need a controller capable of calculating the parity bits at a sufficiently high rate to keep up with the disks, that usually means splashing a lot of cash.It's 4x500gb as the storage drives, the fifth 500gb just does the parity stuff so if one of the four drives fails I can just replace it with another 500gb drive and it will carry on like nothing happened. That's why it's worth it.
Tough, you're getting one - that's really slowBefore I get any 'that's really slow'
At the end of the day for what you're using it for those are the important things, out and out performance isn't always necessary.it runs perfectly well with 100% reliability and is a stupid amount of storage.
