Post Your Home Cine & HiFi Kit...
Thanks
This is what I meant say !
Nice gear!
Just a tip that you either need to resize the images or put them in spoiler tags, otherwise they will get deleted.
Maximum size is 1280 pixels wide.
Had a spare room in my house so decided to make it into a music room, Bought everything used (but in mint condition) from the usual places.. total price was just over £200 and sounds pretty good
[see new post below]
Here's Mine
Samsung 48H6400 Television
Sony STR-DN1050 AV Receiver
Wharfedale Diamond 150 Subwoofer
Onkyo HTP-348 5.0 Satellite Speakers
Playstation 3 with Bluetooth IR adapter
Virgin Tivo Box
Panasonic BDT-110 Blu-ray Player
Wii U
Antec Fusion Max HTPC running Windows 7. Dual Freesat Tuner within WMC and also running Plex.
kaDkkNQH7RVhbj0Whmab47gyg5VwijQ_U-6ZKz8oPg0=w858-h643-no
The Amp and Sub were only installed today, hence the relative tidyness of it :)
zLFgWI0tpevcVJxR06hTTDj4iQ8kfMD3DzYH9fVxbq4=w858-h643-no
0nqrTLVpmcL7Q_pPcDD8vbPDdTO5saMdzQnvq2tVNxI=w858-h643-no
Definitely a step up from the old Onkyo HT-R390 Receiver with passive subwoofer.
I haven't completely tweaked it yet, but the auto calibration seems okay, if a little full on the sub. The speakers are 80Hz to 20Khz, so I have set the crossover to 80Hz on the receiver. The sub goes from 35Hz to 85Hz on its crossover dial so that is set at 85Hz. This is my first active sub and I connected it via a single to dual RCA Subwoofer cable (dual at sub end), I have done lot's of reading on the way to set this up but happy to take any obvious pointers.
New TV for the lounge. Been wanting to upgrade from my trusty LG 42" for a while, but could never decide.
For me the TV choice at the moment is pants, they haven't really made a top notch 4k TV yet and you can't even buy a top notch 1080p set anymore! I was waiting and waiting for a PS64F8500 or similar but they're like hens teeth. The death of plasma is a tragedy, LCD is just pap imo even the very 'high end' sets of 2015 can't compete for contrast of 5 year old pannys/pioneers. What a waste.
Anyway the solution for me was a cheapo set :). I'm actually a DTV Software Engineer for the company that makes these so I'm confident I can get the best out of it, and it was dirt cheap.
Finlux 65FTE242S :D. I still have my JVC X-3 in the dedicated room for proper film watching, but for gaming and TV this thing is great.
Going to calibrate and post my results tonight.
Hmm...
https://www.avforums.com/review/finlux-65fte242s-t-tv-review.10961 said:
Finlux 65FTE242S-T Picture Quality
The first thing to say about this Finlux is that it’s very intolerant of low quality sources. We’re not exactly sure what panel they are using but it appears to have low bit depth so if the source is of even moderately questionable quality, you are likely to see blocking and colour banding (strange hues in colour transitions) effects, especially in darker scenes.
To put that in to context, a 1080p stream of Extant from Amazon, via the Fire TV, could look distinctly ropey in the blacker moments but otherwise it did look really good. A good Netflix Super HD stream, on the other hand, would definitely look better but that is still nowhere near a match for what a Blu-ray can look like on the 65FTE242S-T. This is definitely a TV for disc lovers over streaming viewers, so take that knowledge with you during the decision process.
Good job all I watch is 1080p Bluray from my HTPC then ;). Fact is if I can calibrate this OK (again from HTPC, no TV controls required) the panel itself is more than capable. I'll post the results later and see how it does. At the end of the day you can't buy Plasmas anymore and I can't afford OLED, LCD performance is really not that varied so what's the point spending mega bucks for marginal (if that) improvements.
I've got an LG Plasma hooked up to one of their 5.1 Blu-Ray kits. It's nothing compare to some of the stuff on here but it keeps me happy!
