Your TV probably doesn't support 5.1 passthrough over the HDMI connection from external sources. As Howard says, connect an optical connection from your Xbox directly to the amp and change the audio settings to optical. Et voila.
Thank you sir, connected directly and the true 5.1 sounds a lot better!No, ProLogic is upconverted stereo. You'll need to check your TV's digital audio output settings. Failing that, connect the Xbox directly.
Still got the Panasonic TX-P50G10B
RX Yamaha 567
Boston Acoustics Soundware Xs Speaker and Rear and Sub
PS4
Using the Hole Saw making extra hole for PS4 And AV to feed the cables through and three small holes to let heat escape and 4" USB Fan to blow heat through the Holes.So i can have the door Close
The Subwoofer is side the sofa.
How is the low end on these mate?
My new PMC 21's with the matching PMC stands.
Guys I'm looking for a 4k projector.... I don't want to spend a fortune, any suggestions?
I'm pretty sure cheap 4k projectors are not native 4k. Last time I looked a decent 4k projector was around the 5k mark.
https://www.projectorpoint.co.uk/optoma-uhd550x.htmlGuys I'm looking for a 4k projector.... I don't want to spend a fortune, any suggestions?
