Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
If they give us a heads up at least otherwise I need to pick up a ups or two.
If it's planned then they have to....
Well they say that....If it's planned then they have to....
And a proper mechanical till....Like back in the '70's, go to the pub. One with hand pulled beer OFC.
And a proper mechanical till....![]()
What happens if you have electric heating
Thats not going to help you unless you're on ADSL though... all of the VM cable cabinets and BT / Openreach cabinets need power to function.I’ll have to do the same. You can build a UPS for a router that lasts 24 hours, there’s some plans on YouTube.
I would need one for my switch and server as well. Might look into this see if I can pick up some cheap ones.
Very few battery storage systems allow you to provide power to the house during a power cut. The Tesla powerwall does it, the GivEnergy one does too I think but many others don't. It has to be able to completely isolate you from the grid to stop power going out to the grid during a powercut too (on safety grounds, to stop you electrocuting technicians working on the lines)It's like turning it off, but someone does it for you, remotely, along with all other direct mains powered devices. When it will return is a surprise to look forward to. Those with electric cars and some good electronics knowledge could perhaps convert the battery voltage to mains AC and run the house off the car for a while, then there are gas, petrol and diesel powered generators, or relying on the battery storage of a solar power system. Modern tech' offers many alternatives to the candle and running on the spot.
