Power to weight ratio of your car?
155 bhp 434kg with half a tank of fuel = 357.14 bhp/ton
As soon as it's through IVA it's being treated to a turbo :)
My stripped Saxo with Cobra Imola buckets & 4 point 3" harnesses was awesome on a spirited drive. The way you were held in and the whole noise of the car, made you really feel connected.
However day to day it was a chore! Changing radio station, reaching for anything in the passenger footwell required to undo or slacken the harnesses, the heat from the exhaust tunnel burnt your leg, when it rained bits of water spray found their way in through the car, the noise of the exhaust and every single stone hitting the bottom of the car etc
Using the car for every day duties drove me insane, and trying to explain when picking anyone up in it why I thought my Saxo was a race car!
I'd do it to a weekend car, but then if I had a weekend car it would probably be a Caterham anyway :p Fair play if you can put up with it though :)
I think it's about time the manufacturers all had to comply with some much more accurate weight measurements...
Two few things annoy me about the current system:
It's not clear what options are included on the car to see how representative it is. Perhaps manufacturers should provide maximum and minimum weights for each model to cover the range of options.
Secondly, the EU figure includes 90% full tank of fuel. How ridiculous! Surely the figure should include a fixed quantity? Say enough to fill fuel lines but tank otherwise empry? This 90% system penalises cars with big tanks.
I wonder if better weight measurements would create a bit more competition between the manufacturers, leading to better awareness of excess weight and ultimately a reduction??
If anything it should be a fixed amount of fuel but I can see why the manufacturers would disagree. After all, something like a 7 series has a huge tank for a reason compared to a Kia Picanto. 40L of fuel will certainly affect the Picanto more than it would affect the 7 in terms of the overall mass of the vehicle. 90% handicaps cars in "the same way" as in most cases the fuel tank size is pretty much proportional to the vehicle size (and thus roughly analogous to overall weight) anyway.
Surely this is irrelevant if it effects the power to weight ratio. With less fuel, the power to weight ratio would increase, regardless if the amount of fuel the car was holding was proportional.
We are talking about the EU standard for weight including a standard weight for driver and luggage but not a fixed amount of fuel.
That was the point I was responding to.
Oh right, I thought the EU figure did include fuel. The figures do in the brochure for my car. Either way i think it ought to be clearer. :)
...because accurate weight and power/weight numbers are reeeeeeeeeeeally important for everyone.:rolleyes::p Certainly worth writing an international standard/EU directive/whatever for. If anyone cared would have been done already.
It has been? He just posted to say he would like it to be as clear as the driver weight and luggage has been, rather than 90% of the fuel tank capacity or whatever it is.
As for this EU standard, when was it brought in?
My handbook says 800kg but no mention of 75kg or driver or fuel, I assume all other fluids tho.
The current rules were introduced in 1995 as part of EU Directive 95/48/EC. The EU standard is based on the respective component of the DIN 70020 standard which was published even earlier. These both mandate a 90% full fuel tank and all lubricants, oils, spare wheels, tools etc. The EU standard effectively added the 7 Kg luggage and 68 Kg driver allowance. The idea behind the measurement is to provide a mass close to the actual vehicle in road trim. The 90% full fuel tank works quite well in this regard. Using a fixed Kg penalty would be disproportionate as DRZ explained.
Currently the manufacturer’s offer a smorgasbord of minimum and/or maximum equipment specification benchmark weights, ranges and other figures. There is a good reason for this, as it avoids them having to measure each possible equipment combination. For large vehicle ranges that are sold throughout the world, there could be thousands of weight combinations for vehicles even before you consider optional equipment, as each NSO/importer can ‘negotiate’ their standard equipment packages with the factory to best suit their market. With some effort it would not be impossible for them to provide indicative weights of each optional equipment item, so you could add them together yourself and calculate a new estimated kerb weight.
Something to bear in mind is that EU Directive 95/48/EC allows for a -/+ 5% production tolerance. A car that the manufacturer offers as 1700 Kg EU could weigh anywhere from ~1620 Kg to ~1780 Kg.
Well, given my car is early 80s this doesn't apply.
What my car actually weights when all things are set to this directive I have no idea.
Flukester your comments here are fairly trolling. I suggest keeping out of here for a while, for your own good :)
Any chance of this being copied into the first post? :)
Rank User Car BHP/Tonne
1 Vipernet Race Car - OMS RA 409
2 turbotoaster rx7 twin turbo 400
3 ratface Austin Maestro 396
4 Moorron MK INDY 357
5 mk1_salami Eunos Roadster / MX5 321
6 arcamalpha 911 GT3 313
7 pcoltrane FF2000 310
8 Brycheiniog Sylva Fury 300
9 -Neil- Lotus Exige S 300
10 Muncher VX220 294
11 pwduncan Audi RS6 286
12 Dead Dog Zee Beetle 281
13 Darkman Alpina B5 280
14 NVP E60 M5 277
15 TomO E55 272
16 Anim Celica GT 2005 265
17 Bear 200Sx 262
18 panthro BMW M3 256
19 MacRS4 BMW M3 256
20 Gayjin Evo 7 254
21 ScoobyDoo69 Impreza 250
22 oneilldo Porsche 997 250
23 DM Bentley Continental 248
24 Gibbo Porsche 911 247
25 TomO 200sx 245
26 Princey 6.0l V8 Monaro VXR 243
27 Housey B7 RS4 241
28 Telescopi modified fiat coupe 237
29 BigT Z4m roadster 234
30 beermonster M5 230
31 daveydave Z4M Coupe 226
32 Rich1988 S14a 223
33 Cymatty GT4 223
34 RenoRanes007 '85 Audi ur quattro Coupe Turbo 216
35 Paul_M Impreza WRX STI 215
36 MeEsH BaKkA Astra Vxr 214
37 Nathan Megane R26 213
38 Mucky_Pup Focus ST-3 5 Door 213
39 simulatorman BMW F10 550i 212
40 PMKeates BMW 535d 211
41 Foxtrot26 Leon cupra R 211
42 Vanilla 370z Roadster 208
43 Del Lardo S1 Elise 111s 208
44 _Ad_ Vauxhall Nova 2.0 16v 206
45 VinceB1 Porsche Boxster S 200
46 agw_01 Green 420 Turbo 195
47 andicole0 Mustang 194
48 Kei Saab 900 stage 3 193
49 The Running Man MR2 192
50 Wizardskills Z4 coupé 191
51 tsinc80697 350Z 191
52 McHaMmEr Impreza Turbo 2000 191
53 [TW]Fox E92 335i M Sport 191
54 Dr House E92 335i 190
55 [FnG]magnolia Subaru Legacy GTB 190
56 spaz Megane R26.R 189
57 Sin_Chase S2000 188
58 PiKe S2000 188
59 Alibaba99 S1 Elise 111s 186
60 ThomP Mini Cooper 183
61 sovietspybob Blobeye Impreza STi 183
62 alexisonfire Clio 182 modified 178
63 Mr^B Renaultsport Megane 250 Cup 178
64 LizardKing Mitsubishi GTO MR 177
65 Delboy Megane Renaultsport F1 230 R26 177
66 Witor Alfa 156 GTA 176
67 Sagalout Boxster 2.7 176
68 Rizo-UK Mk5 Astra Turbo 175
69 Dolph VW Passat R36 173
70 Nick1881 Integra track car 172
71 adam cool dude Nissan Primera GT 172
72 Ace Modder Impreza WRX 172
73 Hades Corrado VR6 171
74 Howard MX-5 170
75 Overlag Fiesta ST185 169
76 thepeteh Volvo V70 T5 2.3 168
77 Confused Mitsubishi Legnum VR-4 167
78 MikeHiow Clio 182 166
79 mjt BMW Z3 3.0i Coupe 164
80 Alex_6n2 106 Gti 163
81 The Running Man Corrolla 156
82 Nick1881 Lexus IS300 155
83 Gaygle BMW 330i Sport 155
84 ThomP BMW 330ci 154
85 Marine Iguana Escort RS Turbo Cab 153
86 EndlessSky Volkswagen Scirocco 2.0 TSI GT 152
87 NathWraith MkIV Supra NA 151
88 Howard Mondeo ST220 151
89 Skeeter Clio 172 150
90 dwarf MR2 n/a* 150
91 DRZ S Class 150
92 CaptainFail! Renaultsport Clio 172 150
93 [TW]Fox E39 530i SPort 150
94 Jaap74 2008 Golf GTi 149
95 Duke Golf GTi MK5 148
96 Conscript MX5 NC 2.0 Sport (Soft top) 146
97 Alibaba99 Saab 9-5 Aero Estate 145
98 Berger Peugeot 306 Rallye 143
99 oneilldo A4 3.0tdi 140
100 GT3 Xsara VTS 140
101 DRZ MX-5 140
102 agw_01 Red 420 Turbo 140
103 Pete19s '96 Megane Coupe 16v 137
104 nickrose Alfa Romeo Mito 155 137
105 Smokey McPot Clio Williams 136
106 Dandle 530D Touring 135
107 Raymond Lin Yaris SR 134
108 mattyprice4004 ZT190 133
109 Vigoro MX-5 130
110 UKDTweak SLK 200 Kompressor 130
111 GT3 MR2 GT-Tbar 129
112 Bennie-Mac Toyota Celica Gen 7 127
113 Concorde Rules Volvo V70 D5 (chipped 2008 model) 126
114 mattyprice4004 ZS TD 124
115 Mud *Peugeot 206 GTi 122
116 Liampope Omega 3.0 122
117 cokecan72 VW Passat SEL 121
118 Skyboat Ford Puma 1.7 120
119 killer_uk MK5 Fiesta Zetec S (Modded) 120
120 Moorron RR classic V8 119
121 Hxc MX-5 119
122 Curio Toyota Camry Hybrid 119
123 EliotG Grande Punto Turbo 117
124 ZG002 Swift Sport 111
125 Vita Toyota Yaris T-Sport 109
126 ashrobbo Ford Fiesta Zetec s (59' Petrol) 109
127 Evilpaul Mazda MX-5 1.6 (Mk2.5) 108
128 Wizardskills Triumph GT6 Mk1 106
129 Mr-White Audi A4 2.0tdi 105
130 Muffin` Mondeo STD 104
131 PhillyDee Rover Streetwise 103
132 Wayne~ Panda 100Hp* 100
133 Concorde Rules Mk1 Golf 100
134 Locky Vx zafira 1.8 97
135 Jonnycoupe Gen1 Honda Insight 95
136 Jokester Honda Civic 2.2 i-CTDi 94
137 andy_mk3 1.6 8v Astra (C16SE) 92
138 Orange Peel Mondeo Titanium Sport 88
139 Gamefreak501 Spitfire 83
140 alx Ford Ka 79
141 Vipernet Avensis D4D Estate 78
142 tsinc80697 Fiesta 75
143 Jjustme Mk4 Astra 1.4 16v Petrol Enjoy 74
144 ng93 mk2 Polo 73
145 ThomP Vauxhall Astra DTi LS 70
146 Scubascorpion Pug 106 1.5D 69
147 Flukester Hyundai i10 1.0 Auto 67
148 frozennova golf 1.3 65
149 MANFACE Mitsubishi Outlander Elegance 58
150 NathWraith VW Polo 1.2 50
151 R420LA6X2/4MNA Scania R440 10
