- 13 May 2003
I'm looking to upgrade my router for one that will work with a table. I've got a table that I plan to convert into the router table, made a fence already and plan to buy a mitre track to embed in it shortly for ~£10, and I have a router plate in mind (kreg). However... I don't think I can fit the router I have to the table because of the switch (it doesn't have an off/on but is a plunge switch), and whilst it might be possible to rewire it I'd rather not. It's a no-name brand that isn't very powerful - it was given to me from a garage clear out - and I have been practising a fair bit with it and plus I'd quite like the opportunity to upgrade a little.
I don't really have many requirements in mind, but I'd like one powerful enough to deal with hardwood as I use that regularly, and I want one that is easy to change bits/adjust the bit height without having to go under the table, if that is at all possible (I realise I might need to drill extra holes in the router plate for that, this is not a problem).
Any suggestions?
I bought a Triton TRA01 https://www.screwfix.com/p/triton-tra001-2400w-electric-dual-mode-precision-plunge-router-240v/2491k great for a build your own router table. You can remove the spring, it has fast adjustment and microadjustment and can be micro adjusted through the table top. The bit change is a doddle as it has a locking mechanicsm that self locks when you descend to bottom of travel then just use the spanner provided, also the descend will takethe collet above the table top so bit change is really accessible. Comes with standard 1/2" and mwtric equivalent collet 1/4" collet is available. Loads of power, solid features a good build your own option. You want a decent insert though it's a heavy beast.
