- 21 Sep 2020
That video is brilliant.
Yes very useful. This is the video i saw a week or so ago when i was investigating how to cut the corner ends of a skirting boardthat is so useful. I've watched a handful of youtube videos but nothing as clear as that. Ok, it might be doable with a jig saw after all. Fantastic. All I need to buy is a sliding bevel
It will not be small, it will not be quiet, it will not be portable (well, it will need to be plugged into the mains all the time).So as usual, in my haste I mis-read a product advert and failed to notice the brad nailer I ordered requires a compressor: https://www.screwfix.com/p/makita-af506-50mm-first-fix-air-nail-gun/791XJ
Could someone help me make heads or tails of what type of compressor I should get? From my reading so far it appears I can buy pretty much any air compressor that can kick out 70-120 psi, and then just find a hose (?) that can connect to both the nailer and the compressor?
Let me know what you think? tempted by one every time they pop up on hotukdeals but its probably overkill for my needs.DeWalt dcf899 has finally turned up, it's a beast, it's massive lol!
Those kits are loss leaders (or certainly zero profit) for the likes of Screwfix etc.The pricing is confusing me, I paid £100 for the dcd709 drill plus 2x2ah batteries, charger and case.
Just the bare tool impact drivers seem to be £80-100 I would expect more like £50?
Also will the standard tstak case fit both tools?
Can anyone recommend a good variety bit set?
The ones on the market all seem to not offer much variety. Eg the dewalt 37 piece impact set only really has several different lengths of either PH2 or PZ2 bits. I don't need 10 bits that are the same I want a wide variety of bits for all types of screws or sockets. Allen bits, torx, torx security, male torx, female torx etc.
