Thanks Skiddley, would this one do the job?For plinths, personally I use a jigsaw as they invariably need scribing to the floor.
The second option is a Dewalt Drill & Impact Driver set, coming with 2 x 1.5ah Batteries at £149.99
Just bought the DEWALT kit.So the time has come to replace the drill & I'm considering quite a few.
The first bus the Ryobi One + System which is a Drill Driver kit with 2 x 4ah Batteries. It's £158 & also going to get an impact driver which is £60 and can use the same battery system
Makita is unfortunately out of my price range. Anyone got experience with these? Not really had Ryobi tools before.
Did think maybe brushless was worth paying more for, and that for my occasional DIY usage, separate drill and driver might be a waste, but the consensus seemed to be that brushless wasny worth it for non-profession use, and an extra driver seemed like a handy ikea flat pack assembly companion.
Battery-wise,again,the consensus seems to be a couple of 1.5As is ideal to keep weight down, but still offer enough juice for all requirements.
Hope that's of help.
Yes, I did too, and reached exactly the same conclusion. The Brushless DCD795 is available on Amazon for £73 -Thanks, I did look at the Brushless set here : http://www.screwfix.com/p/dewalt-dc...-xr-brushless-combi-drill-impact-driver/2952r , But it's another £100 and not sure it's really worth it.
Or maybe this one which is Bushless and also £99
http://www.wickes.co.uk/DeWalt-18V-Li-ion-Brushless-Combi-Drill-DCD795S1-GB/p/150231
http://www.screwfix.com/p/makita-cl...ion-combi-drill-impact-driver-twin-pack/9372p This isn't too much more expensive, and whilst admittedly its the lower end of the Makita range its still Makita.So the time has come to replace the drill & I'm considering quite a few.
. I was lucky in that I got the Makita 18v set thats £250 now for £160.
