Ah, thank you, that's a good point regarding the skirtings being all different angles. I don't think there is a square corner in my house.Yeah it was rage 3
Cut a lot of flooring and not had an issue (I think skirting should be scribed rather than cut in the corners anyway?). Also mitred some Scotia. For DIY use I'd recommend.
For cutting skirtings I dont think the squareness will matter as the edges will all be relative.
We're still undecided on flooring at the moment but if it is wood/laminate the saw will be put to good use.
. £30 down the drain, where as a jigsaw blade is like 30p. Plus a single jigsaw blade from sharp will do an average sized room of laminate because of the way it cuts on the up stroke it tends to just break the melamine, rather then cutting through it.
