- 13 May 2003
Really to do what? Lighting?Fish tank
Also worth looking at the 796, although it's a bit more expensive as it is higher spec and more robust, but you can get it with 2x2ah batteries for £150 from toolstation. I think the 2ah batteries are better balanced for a small drill.
https://www.toolstation.com/dewalt-dcd796-18v-xr-li-ion-cordless-brushless-combi-drill/p30986
If anybody wants a top quality 18v combi drill then Screwfix (exclusive to them) have the DeWalt DCD778M2T-SFGB with a charger and a pair of 4.0 AH batteries for £149.99, that's £100 off and the price goes up in January. It's a lot of money for a combi drill but I need a replacement for my old Silverline whose batteries no longer hold a charge so I am probably buying this and picking it up in town on Saturday.
I’m going to be hanging some new doors soon, they’ll be standard hollow doors, nothing fancy or hardwood. What’s the best tool for trimming the bottoms? Electric planer?
Anyone got any recommendations? I think it would be fair to say this is likely to be the only job like this I will be doing so it doesn’t need to a high end model, just one that is sufficient. Prices seem to vary significantly. I have screwfix and tool station nearby and online of course!
Go for this much better made and specced drill, if you can stretch your budget and wait for an Ebay voucher you can get the DCK266 which is the 796 and 887 Impact driver with 2 5.0ah batteries and charger for around £250.
My kit is brilliant and don't know how I've lived without a impact driver for so long.
Hollow doors are quite simple or “egg box doors” us chippys call them. Don’t waste your money on power tools if you won’t use them again. If you have a block plane handy just use that and a hand saw and take your time. If you don’t have a block plane then just try and pick up a really cheap electric planer or borrow one if you can. Take your time and plane off small layers at a time. Get the door in tight first then trim as necessary rather than all in one go.I’m going to be hanging some new doors soon, they’ll be standard hollow doors, nothing fancy or hardwood. What’s the best tool for trimming the bottoms? Electric planer?
