730w.
Also from today's ride. A gentle pace with 1 flat-out sprint up a hill and 1 flat-out sprint at the end.
730w.
Username - DanF....
Do we just take the 1, 5 second data etc from Strava?
Nice effort. I managed a new pb of 355w for just over 15mins this week which I was pretty happy with. Hopefully I can get over 350w for 20mins in the not too distant.
Been doing a fair bit of sweet spot work over the last two weeks which I think is really helping.
To generate power you need resistanceOh, I appreciate that it needs to be considered with a mountain of salt, but even so there is still marked variance between the numbers it dreams up when I'm cruising on the flat and when I'm climbing.
Downhill : There is little to no resistance going downhill, so to generate power you need to push in a harder gear. If you're cadence is spinning out or you're soft pedaling then you will generating very low power, maybe 0-50 watts
Chances are a lot of the time on the flat you're soft pedalling too, no offence, but especially at the sort of speeds you average, but nonetheless something that I noticed when I very first got a PM.
292watts for 22mins on a mountain climb yesterday
Been weighing in at 58/59KG's as well this week = 4.94W/KG
I reckon I am right around 300watts @ CP on my next rested and proper test over 20mins which puts me over the magic 5w/kg. GC has modelled my data to a 306w CP as well so it's all coming together![]()
xdcx, you're a bit of a pro with Golden Cheetah, why now everytime I open 3.2 it does the whole upgrade to 3.2 thing, again, each time.
I haven't went to 3.2 yet purely because I run GC via Windows at home but Linux at work and sync my athlete DB over Dropbox. There is no 3.2 package yet on Linux so I am just waiting for it rather than mucking around with 2 different versions between my machines.
From what I read, first launch of 3.2 should look at your athlete DB and convert everything to JSON. So typically it created a .bak from your device for the .fit and then generated a CPX and a JSON file for each ride.
When you open 3.2, let it do its thing and keep it open once finished. Then jump to your athlete DB dir on your machine for me and let me know what the state of that is? Does it retiain everything as .bak once it converts or does it actually trim the who data structure down to 1/2 .JSON per ride you have in there?
Purely off top of my head as a thing to try though would be to open GC 3.2, let auto convert occur. Keep GC app open and then copy/paste the now converted JSON dir structure into a new directory somewhere on your machine.... Then once that copy/paste finishes, amend your GC settings to change your athlete DB and workout lib (tools>options and bottom of the general tab those 2 boxes) to the new directory you created with the converted JSON data structure.... Close and re-open GC and see if it now points at the new location and obviously you'll see if it does a re-convert of the data structure yet again.
If you are still getting issues I will upgrade this Windows machine and just go 3.2 as there is some nice changes I want. I can re-build my GC on my Linux box at work from source and stopping being lazy waiting for a package and then I will be much more help to get it sorted out for you if needs be![]()
I'm not at home at the moment but will probably have a crack tomorrow afternoon. Liking it so far though. The W' numbers being the most interesting. Think that'll be the next big thing tbh. Would be awesome to know what's left in the tank at a particular time in a ride.
That and just the ride page with added marked intervals on etc.
