Powerful Cooling
Access to the MM??
I have a K2 for sale which was using a single TY-147 instead of the stock fans. It was stunning and kept my 2500k @ 4.5ghz below 50deg.
Only changed to a CLC to tidy the inside of my case :D
I'm going to keep the H110 now tbh.
I'm really tempted to take it off and try the Gelid paste, but knowing my luck ill get worse temps if i try again. Should probably just leave it well alone now lol.
its definitely uneven from those pics
either the mount or the cpu ihs,im getting 6c diff on one core
idk what to suggest,other than trying to get it to mount evenly on the cpu
EDIT: only other way is to lower your oc/volts to suit
try and count the turns on each screw so they are all the same,if its still odd temps then loosen one side quarter turn and tighten other side quarter turn ect might help
That sounds incredibly tedious, but worth trying. Its going to be a long afternoon.
