You tried changing it in bios or using Motherboard preset?CAn't seem to get my 3800X to use more than 70W of power even when using Cinebench 20. Any ideas?
yea I would have thought so as well...i have a 360 rad cooling this so thought i would easily get the 4.4 boost but nothing I try is helping, reseated the block today with fresh paste and made sure it was spread all over the cpu as I have read it needs to be a good covering across the whole of the ihs.Should be doing more than if cooling is ok, mine does 4175-4300 allcore with pbo, 4000-4150 without (noctua d15s).
Put the history graph on to see if it was boosting to 4.4 or use hwinfo.
Had a look in the BIOS and it's on OC mode if that is the correct setting. CPU will boost fine to 4.5Ghz+ but NEVER draws more than 67WYou tried changing it in bios or using Motherboard preset?
My Settings for boost up to 4582.1Mhz
OS-1903 Build 18362.267
AMD ComboPI1.0.0.3
AMD_Chipset_Drivers_v1.07.29.0115-Release -July 30 2019 with AMD Ryzen™ Power Saver Plan
BIOS set to Enhanced Mode 4 for MSI Motherboard
My settings for videos boost up to 4525Mhz gaming/Cinebench
AMD ComboPI1.0.0.3
AMD_Chipset_Drivers_v1.07.07.0725-Release Day -July 7 2019 with AMD Ryzen™ Power Saver Plan
BIOS set to Enhanced Mode 4 for MSI Motherboard/LCC CPU/SOC 2
Well no problem at all.This is not directed at you,just letting people know who are hung up on the numbers.Thanks for the detailed info. You really have a nice chip.
Defo not boosting properly-before we even start talking about pbo, what other same bios boards users recon?ok...here is hwinfo
Boosting above 4.5 GHz (around 5.1GHz 9900k for comparison) , complaining it only consumes 69 W
Boosting above 4.5 GHz (around 5.1GHz 9900k for comparison) , complaining it only consumes 69 W(if those readings are true, which I doubt)
Did you actually go into BIOS and set manual limits past 69W,just asking.
