WHat is AGESA, bios version?
AMD CPU Microcode, essentially.
To be fair to @Jacky60 My 3900X hasn't seen above 4.44GHz in any loads that I've thrown at it.
How do you update it though through chipset drivers or is it built into the BIOS?
3700X with X570 Taichi. Max boost with any settings 4.3ghz. BIOS is plain broken when it comes to boosting. Using Ryzen Balanced power plan, is that still the best setting?
4.3ghz all core 1.35V is stable for me though.
So I duno but does this voltage look especially high? I have everything on default and precision boost turned off in driver and BIOS, I am on Ryzen Balanced power mode, my core temps are 44.4C and this is running rise of the tomb raider...
https://ibb.co/d7hnjXV
That's pretty good! Even the 'slower' 6 cores are doing quite well, do the 4.5/4.6ghz clocks hold for a decent amount of time as in not just a momentary peak beforeScrap that, I updated W10 to 1903 because I forgot it didn't go through previously. Then I reinstalled the latest chipset drivers and huzzah:
dropping back? Ideally I'd want at least one thread flying along at 4.6ghz for as long as needed.
Looks normal for stock setting, pbo off.Hi
Can anyone tell me if there are any issues here. currently running cinebench and get these readings. is it normal....only boosting to 4.1. The cpu is under custom loop by ekwb 360 rad.
photoupload
Hi
photoupload
pbo is onLooks normal for stock setting, pbo off.
