Project: Aquasidian (Corsair 800D)
  • Thread starter Thread starter Nem
  • Start date Start date
Sorry, it's not the Dtek is made by EK WaterBlocks. It's the swiftec 655 / Lang D5 pump but with a different top to allow different inlet and outlet options. The part is called "EK-D5 X-TOP - Acetal G1/4 Rev.2" if you want to have a google for it.
I think the tube is 3/4" but I'm not certain so you'd need to check the info for the Tygon tube.
Nick
Nick
Awesome, thanks so much for your help. Last questions (I promise!), what backplate did you use for your cpu? and did you use any hose clamps?
Sam
The backplate was just the one provided with the swiftech cpu block.
All the fittings are compression fittings so no clamps used.
