So, updates.
1) The engine has been set up again. Turns out we were waaaaaaaaaaay off-base with our attempts at doing it. Our friendly neighbourhood lunatic mechanic Scott went ahead and sorted it. Running very well now.
2) The rear bumper is off for some fettling. If you look at some of the photos earlier in the thread you can see where it's been mis-shapen and damaged over the years. Rear end doesn't look great without the bumper:
Should look mighty fine with it back on having been fixed though! Repairs are ongoing, but it looks really good. Both endcaps have been straightened and repaired, the metal trim has been sorted....everything should go back where it's supposed to now.
3) More bodywork has been done. Specifically, left-side doors and part of the rear quarter panel on that side. Smoothed out the wrinkles (they were pretty obvious in some light levels, so definitely needed immediate attention), and paint matched up. The other side will need doing eventually, but right now a ******* good polish will do just about as much good. The paintshop did find evidence of several resprays, mind. We think this might be the 4th time those panels have had paint over the years.
4) Boot lock has been sorted. The owner and I had a bit of a tiff over this. He was being a moody twit saying it wasn't fixed at all after it came back. I left him to his own devices in the pub, went over to his house, opened the car up, opened up the fusebox and pushed the central locking reset switch. Job done
5) So, state of play. We've got to get the centre console up to look at the seat memory switches and replace the rear window isolator switch. We've got to get the leather on the front seats (drivers seat in particular) brought back up to scratch. Refit the bumper obviously. And then....well, that would be about it. Oh yes, and some of the door and window rubbers need doing. And it might be an idea to look at some new tyres next year. And we've got to add some insulation behind the door cards, sort out the drive belts for the engine bay (no aircon belt ATM as we finally twigged that the one on there was the wrong size
), maybe look at the rear screen and see if we can't sort the laminate out, sort out once and for all that God damned twittering sound coming from behing the dashboard (!!!)....
Could be worse I guess. No matter how many things keep cropping up with this car,
we've got nothing on this poor sod's Charger....
