PhillyDee said:You can get the couble barrelled foot pumps which pump air a lot faster . . . Should be able to get more pressure that way.
Jonny L said:The problem is, we have to pump it up manually, there are no electrical devices or chemical reactions aloud.
On the knowing how far it goes part, we are going to fire it across our school field.![]()
It's a bit more ghetto than the ones made from plumbing pipe. Ignition is a Zippo lighter held to the hole in the side down near the bottomp4radox said:Jonny: is that similar to the infamous potato cannon?
What's your ignition?
PanMaster said:Can you send the golf ball over 10km?
http://www.powerlabs.org/cannons.htm This guy can.
Rich43 said:Cant you use some sort of electronic valve to trigger it?
then you could have a long cable.. flick a switch and bang!
Jonny L said:I'm thinking we make billy do it first, just in case ...
FrostedNipple said:...he comes back with an air tank which are used on airliners for storing emergency air, they are rated at 1000psi,
adfinni said:We were only running at about 6 bar, but could fire our ball 200 yards up a hill, at about 45 degree angle. But we were using a £400 fast acting open-close valve to fire the thing.
paddy said:6 bar is about 90psi - so your running on a similar pressure,
you could go up to nearly 70bar (~1000psi)
I have 2 scuba diving tanks next to me rated to (and containing air) at 232 bar (~3300 psi). Party at Paddys house !![]()
We need to see videos of this
FrostedNipple said:will get them shortly, as in tomorrow, hmm i figured that the tank is actually rated to 3000psi, i worked that out by reading it on the side of the canlol
MikeHunt79 said:PTFE tape
