It'd look awesome if you were to change to something like an Aurora fluid in the future having the clear acrylic.
Or, you could stick with copper, and instead paint it white. This will give you the same overall effect, and will probably be cheaper!
Painting copper pipe will make it harder to change the colour scheme later, if it's clear you just change the fluid.
