Got some Updates after a long time!
While waiting for the replacement PSU I made some changes.
Had to change the PSU extension cables as one of the older ones had a fault of some sort, so I got all white cables.
Removed the GTS240 RAD from the loop.
This helped to position the pump better, also resulting in removing 2 of the 90 degree rotary fittings.
While I was doing the leak testing for the second time, I got the replacement PSU!
I had a 850W unit first but because it was out of stock for nearly 2 weeks I had to settle for the 750W unit instead. I am sure 750W is enough for my future needs as well
I also got this!
It is the Aquaero 5 LT.
After doing some testing with the AA5, I noticed the power amps are getting a bit toasty for my liking.
When running the fans at lower RPMs they tend to heat up to 75C!
So I did a small mod.
First I fixed some spare VRM heatsinks, and then attached a 60mm fan as well.
Now they don't go above 55C.
Removing the GTS240 RAD and the 90 degree fittings seem to have effected the temps in a good way.
Idle temps are not so different, but the load temps have come down a bit! I will have to do more testing while keeping the same room temp.
At the moment I am experimenting with the Aquaero 5's settings. It is a brilliant little thing but very poor documentation!
I still have to do the Side Window, Mid Plate and the Front Plate.
Have plans to put some temp sensors and a flow meter to the water loop.
Also need to tidy up the wiring in the bottom compartment of the case.
I also got this!
