Lovely build m8, could you please link the 2 bits for the QDC, also what did you
Use to mount the SSD to the back?
OCUK website does not have or have the incorrect picture for the item, but if you do a search for the following you will find them.
VL4-M13-19S
VL4-F13-19S
These are for 1/2" ID 3/4"OD tubing, they have the compression fittings at the end.
VL4 version will spill a tiny bit of liquid when disconnecting, but it would be about 3-5 drops and once you get the hang of it, even that is easily avoidable by the way you turn the QDCs. I have used them many many times, they can be a bit big for certain loops but can be useful non the less.
In my latest loop(not shown here) I have removed them to see how much of an effect they cause due to restriction/flow.
I used a AQ High flow meter to measure the flow rate and they made no difference in terms of flow
So I am going to put them back in next time.
There are VL4
N variants that has no spill at all! and the new QD4(and QD3) models koolance have released this month are smaller and even less restrictive than these while keeping the same no spill characteristics.
I used "no more nails double sided tape" for this.
It has a strong enough tape to hold my 480mm RAD stand(with the RAD and fans) in the case with just 3 pieces of tape underneath! And I can't move it.
For SSDs I use a tiny bit of it(about 5mm on opposite sides) to hold them to the back of the case and to each other. They are 1mm thick so much better than velcro
