So here it is with the rads in! (need some more compressions now... there goes another 10-20 quid but oh well :/)
got some major re-organising to do with all my cable tidying. res + pump should be fitted by tuesday then I have to sort all the tubing lengths out... and finally leak test (hoping that theres no leaks when I attempted to flush my rads using my pump a couple of the fittings were leaking... and no matter what I did they wouldn't stop :c)
I had a little issue with a bit on top that holds the filter in for trying to have one in pull outside the case. Tight fit though with a full rad.
