Both sidesif you look the bottom is currently the inlet and the top will be the outlet.
Oh yea, didn't spot that first time around
Varnish? that sure is an interesting suggestion, don't think i will be trying that any time s...in fact, ever.
So my motherboard just had a bent pin (just the one... No idea how I managed that) but itll be back to me soon and I can build my pc (minus loop c'mon ocuk get the pump top in stock! D: )
) this will be the hardest part due to where I plan to put my 120mm rad I'm not quite sure where I'm going to put the pump currently :/ Pics sometime soon... trying to sort my motherboard out still.
This weekend will be an interesting one mainly full of planning it out and possibly a dry loop setup if I'm lucky!
here's a pic... not great but you can see my 670 has the block on and I've put the CPU block on finally
