PROJECT: MAGNUS AQUA DOMUS!
Panel in and just making a start installing the wc gear, looking better already, the 280mm is no longer in the loop.
In all honesty because the provided screws were too short and I couldn't be bothered waiting until tomorrow to source out some longer. I'm sure the equivalent of 5x360's will cope :o
Getting there: http://db.tt/tfRyeRaB
Yeah yellow pastel, bleed isn't going to take long at all, dual d5's are ******* rapid!!! Guzzled down 2L so far in around 3 mins :D
Possible, it's a hairline crack above one of the ports, must have been where it was leaking before, I thought it was a worn seal on a compression :(
I'll grab some epoxy tomorrow and seek other alternate suggestions on the wc forum.
Think this one may be better off in the skip. Gives me an excuse to buy an SR1 though!
I am completely exhausted, I've been at it non stop since around 1pm. At least when the replacement rad arrives it won't be much hassle swapping it out, even managed to get away with only having to drain off around half a liter of fluid, god bless QDC's and the fact the 360 was the last component in the loop.
Will update with some resized pics from todays ventures shortly.
The start of my day, mocking up the cover panel:-
Big ol bracket holding things steady at the bottom, while the top is pinned into some spare HPTX stand-offs:-
Figuring out rad positions, where I realised I wouldn't be using the 280:-
Getting the tubing in:-
Start of the leak test, dual D5's are unbelievably rapid, if it wasn't for the bust radiator it would have been filled and bled inside 10mins, with a single D5 it took nearly an hour:-
That last pic is like a Bullseye "look at what you could have won" to me :(
I will Email EK and show them, though I think my raw power was too much for the little EK Radiator :(:p
It may be a defect though, as I don't see any other dents near it like its had too much pressure on it or something.
I'll try it out :)
Though it may not sit well, the inside faces of the bracket aren't flat, it changes in thickness towards the center as its designed for holding T-Pieces on hard line air installations.
I may chop up some angle bar at work durring the week to make the bracket a little more subtle.
