Project:- R3s
I bought an r3 last night for £59 :D and also a pump and res for my main rig, so I'm not sure whether to watercool this rig or not (I'm pretty sure what most answers will be on here :p)
yesterday when I got home from school I was greeted by this at the side of my house :)
009 by Kieran Horne, on Flickr
it's taken me up and till now to build it and post the pics, mainly because I was also re-doing my skelly's watercooling loop, I did have a couple problems too, but it seems to be all good now :D so enjoy :)
021 by Kieran Horne, on Flickr
001 by Kieran Horne, on Flickr
009 (2) by Kieran Horne, on Flickr
011 by Kieran Horne, on Flickr
Xigmatek fans installed:
015 by Kieran Horne, on Flickr
018 by Kieran Horne, on Flickr
023 by Kieran Horne, on Flickr
the cable management is slightly different than this now, but not by much :)
034 by Kieran Horne, on Flickr
040 by Kieran Horne, on Flickr
last shot from yesterday, windows wasn't installed at that point:
046 by Kieran Horne, on Flickr
Then I ran into some problems, mainly, the 260 wasn't displaying properly, so I tried to use my 460 to see what was wrong, it wasn't working with my 460, so after a while I decided to see what clearing the cmos and moving the 260 down a slot got it working :)
059 by Kieran Horne, on Flickr
I thought the xigmateks were a little loud after installing windows so I decided to replace them with my orange bitfenix spectre fans and do a little more cable management, now the system is whisper quiet :D here is the finished product:
htpc complete by Kieran Horne, on Flickr
Thoughts on the case:
I love it! it's soooo sleek and gorgeous, the finish is amazing!!
there are only two slightly negative things I can say about the case, one, the rubber grommets are too flimsy, and that there are no cable tie down points nearer the back of the case.
Hope you guys like :D
thanks :D I quite like the stock cooler on it, but I would prefer a better card :D I like this case so much that I'm considering moving my main rig into it!
I noticed half way through you changed the mounting of your PSU :p
Out of interest, you ever tried taking it apart? (Clearly it voids the warranty), but I have one myself that I was considering painting, and for the life of me, even after unscrewing the void warranty stickers I couldn't work out how to get it apart -.-
kd
yeah, I like having the fan facing up like ttl does, but the 8 pin was too short :(
no I haven't, but I did consider changing the fan and braiding :)
Pretty much certain that I want to move my main rig into this case, so I need a little help deciding what to do, should I:
1. have a slim 240/280mm rad at the top and remove the hard drive bays and have a thick 240mm rad in the front
or
2. build a rad box to house the two 360mm rads I currently have, and place it underneath my case
gonna go with all silver bitspower too :D and I'll sell the left over stuff and get some upgrades and wait for the raspberry pi's to come out and use one of them as a media pc as they can run 1080p video! :D
