Project:- R3s
something like a silverstone strider, xfx fully modular, ocz fully modular or a fully modular corsair psu
well guess what arrived today?
DSC_0133.jpg by Kieran Horne, on Flickr
My 5870!! :D:D this will be watercooled later on, but for now, some pics :D
DSC_0143.jpg by Kieran Horne, on Flickr
DSC_0145.jpg by Kieran Horne, on Flickr
DSC_0146.jpg by Kieran Horne, on Flickr
DSC_0148.jpg by Kieran Horne, on Flickr
DSC_0155.jpg by Kieran Horne, on Flickr
after a recommendation from someone on another forum, I decided to use my dad's d3100 with my lens and a white screen for some light, the pics above were taken in this way :) here is a test shot:
DSC_0118.jpg by Kieran Horne, on Flickr
glad your happy with the fans kieran,yes they do look awesome but with my build i wanted to tone it down a bit hence the fans are with you now :)
will be keeping a eye on this now.
My watercooling stuff arrived today :D didn't take pics of the boxes etc, but you guys didn't need to see that anyway :p
Before:
DSC_0639.jpg by Kieran Horne, on Flickr
During:
DSC_0645.jpg by Kieran Horne, on Flickr
after:
DSC_0648.jpg by Kieran Horne, on Flickr
The pump looks awesome, I may remove the sticker at the front and also the screw in bits at the side
DSC_0662.jpg by Kieran Horne, on Flickr
Here's all of my shiny new fittings, do you notice anything different?
DSC_0664.jpg by Kieran Horne, on Flickr
Shiny, very heavy, res:
DSC_0689.jpg by Kieran Horne, on Flickr
The fans from yesterday's update mounted on the rad:
DSC_0705.jpg by Kieran Horne, on Flickr
And here is the fitting that will act as my drain port and as an extension to allow me to use a 45 degree fitting (the extension fitting is just there so I don't loose it :p):
DSC_0713.jpg by Kieran Horne, on Flickr
Until the next update :) ..........
looking sharp bud! I think i am going to give watercooling a go soon, when i have some spare cash i am first going ot get some bitfenix white extensions (lush!) then a ocuk v8 watercooling kit, or the xspx one not sure yet. Any advice/ideas you could throw a brother? I need a theme really any advice would be guuuuuuuuuuuuurd. What it looks like currently: http://forums.overclockers.co.uk/showthread.php?t=18316477 but has since been cable tidied and tarted up a bit.
thanks guys :D I would say that you should go for a 240mm rad and a 200mm rad if you are watercooling your graphics card too :)
Well here it is! the update you guys have been waiting for. Watercooling!! :D
I was able to drill out the case last night finally, and here are the results:
Bare case with drive bays removed:
DSC_0048.jpg by Kieran Horne, on Flickr
Rad installed:
DSC_0067.jpg by Kieran Horne, on Flickr
components in minus hard drives and psu:
DSC_0072.jpg by Kieran Horne, on Flickr
Ready for filling:
DSC_0096.jpg by Kieran Horne, on Flickr
And the final pics, I'll start off with showing how it used to be and then show how it looks now :D
Old:
DSC_0006.jpg by Kieran Horne, on Flickr
DSC_0028.jpg by Kieran Horne, on Flickr
New:
DSC_0102.jpg by Kieran Horne, on Flickr
DSC_0120.jpg by Kieran Horne, on Flickr
DSC_0122.jpg by Kieran Horne, on Flickr
DSC_0126.jpg by Kieran Horne, on Flickr
DSC_0134.jpg by Kieran Horne, on Flickr
DSC_0130.jpg by Kieran Horne, on Flickr
Hope you guys like :D
