PROJECT RESTORE
Well I was searching through my storage today and guess what I came Across...
That's right you've got it!
That's right my old Coolermaster Cosmos S.
So basically this project is all down to restoring my old Coolermaster Cosmos S I have owned this case for only around
2 years now and it's in pretty bad shape. Although I can happily say non of the blame should be on me. It all comes
down to the previous owner, you see I originally bought this case from ebay but the description was of poor quality.
It listed that the case had a few "very minor scratched" although this was a huge understatement in my opinion. Anyway
enough of that time to move on.
What will be done?
I'm planing on doing a black respray of the inner case and doing a glossy black respray of the bars at the top and bottom
of the case. Then I would like to possibly respray the aluminium side panels although I'm not too sure yet as this has a
brushed aluminium effect. And finally I will respray the silver plastic part's this will be either black or a bright orange as I
have not yet decided.
Oh and finally fix the hinges on the doors at the front as they will not close properly.
Anyway keep watching the thread as I will be updating it in the following week's and here's a few more pictures for your amusement.
What will be done?
Oh and finally fix the hinges on the doors at the front as they will not close properly.Anyway keep watching the thread as I will be updating it in the following week's and here's a few more pictures for your amusement.
good luck
