UPDATE: 11/07/2011
Another Big Update today folks. So today I retouched and sprayed some panels still on the primer stages but like 95% done now. Anyway pictures are more fun than words so let's begin!
Well today was a wonderful day very hot and sunny weather, before I could start painting I first had to make myself a snack.
In 1941 the japanese bombed pearl harbour...
In 1969 man first landed on the moon...
in 2001 George Bush was elected president...
and in 2011 I made a damn tasty sandwich...
Anyway to business, Apart from touch-ups and that panel I half sprayed this is all I had left.
As you can see I needed to remove the remnants of crap left over from the rubber that was stuck to this piece which absorbs vibrations from the PSU.
I would also need to sand these bar's down.
So that's just what I did.
I then left my primer to soak in warm water whilst I set up the spraying area.
BAM! retouched this panel.
KACHOW! then finished the other side of this panel.
Before...
After
Then I sprayed these bad boys!
The only issue I have left and the reason I am still 95% through the primer stage is due to the bar's not being able to stand up properly. I could only spray one side successful. So tomorrow I'm going to pick up some string and tie them to my washing line this way I can get the job done without the paint rubbing off. Secondly the square thing which had all that crap on it. Well that crap is damn hard to get off! It wont sand off and a knife didn't help much either. Fortunately I managed to scratch about 80% of it off after soaking it for a long ass time in hot water.
Anyway tomorrow agenda buy string, scrape the rest of that crap off the square PSU holder majiger and finish up priming.
So until then stay tuned
-SKENG-
