This is my 3rd build, but my 1st water-cooled build (wish me luck). As I am trying to take as much care with this build as I can afford, I thought I would share my efforts on this forum
As for the name, I don't know why I chose it, but it's better than no name at all! I may even purchase a scorpian windows applique, don't know yet!
Please note that I won't finish purchasing my stuff until March~ as I am awaiting the ASUS Rampage 3, Intel i7 930, new range of SSDs, as well as other bits and bobs.
I have hyperlinked the products that are available on OCUK. For those that aren't, well you will just have to use your imagination if you want them i'm afraid
SPECIFICATIONS
Current
Case:
Corsair Obsidian 800D
Hardware:
Enermax Revolution85+ 1050W - RMA (2nd time - clicking fan)
LG GH22LS50 22x DVD±RW SATA ReWriter Lightscribe Drive
2TB Samsung Spinpoint F3EcoGreen
Creative Sound Blaster X-Fi Titanium - Fatal1ty Professional
Watercooling:
Heatkiller CPU Waterblock Revision 3 (Socket LGA1366)
Swiftech MCP655 w/ EK-D5 X-TOP Rev.2
TFC Compression fittings 1/2 ID 3/4 OD (x10)
Bitspower G 1/4" Silver Shiny Temperature Sensor Stop Fitting
XSPC 7/16 UV Clear Blue 1m (x4)
XSPC RX360 Radiator - Black
Bitspower Adapter (Rotary 45 deg.), G1/4" to G1/4" - Silver Shining (x5)
Bitspower G1/4" Silver Shining T-Rotary Adapter
1L Feser One Fluid - UV Purple
Air Cooling:
Enermax TWISTER Everest (x3)
Akasa AK-FN058 Apache Black Super Silent 120mm (x4)
Corsair Stock 140mm fans (x3)
Akasa Fan Guard - 120mm
Sythe 120mm Fan Grill (x4)
Accessories:
Akasa AK-TK-02 Cable Tidy Kit
Zalman ZM-MFC1 Plus Black Multi Fan Controller
AKASA Paxmate Plus - Soundproof mats
Akasa 20/24-Pin 30cm PSU Extension Cable
Scythe Kaze Master Ace 5.25inch Fan Controller - Black
Nexus PCI Slot Ventilation Bracket (3 Pack)
120mm Aluminium Fan Filter - Black (x3)
Pre-Wired 5mm Blue LED
4.8mm Heatshrink 2:1 Ratio - Black (x3)
3mm Cable Braid - Black 1m (x8)
3mm Cable Braid - UV Blue 1m (x8)
4mm Cable Braid - Black 1m
6.4mm Heatshrink 2:1 Ratio - Black
Sharkoon 12" UV CCFL 4in1 Kit.
Sharkoon 4" Blue CCFL 2in1 Kit.
Arctic Cooling MX-3 Thermal Compound
On Order
Nothing.
I will update the specs list when I recieve the things I have ordered or I order something else.
SPECIFICATIONS
Current
Case:
Hardware:
Watercooling:
Air Cooling:
Accessories:
On Order
Nothing.
