Any chance you can post your opinion on the AKASA Apache Black fans when you get them installed, i was thinking about getting a couple myself
Well, I tested them earlier, at low RPM they are dead silent, can't hear them at all. With the fan controller, if you turned it all the way down the fan actually switched off, which I thought was really cool - I'm guessing that's a feature of the fan.
It looks sleek and mean at the same time.
Once you bump up the RPM it starts to become louder, but not excessively loud. Overall I would say it's a brilliant fan.
The only 'downer' is that it uses the new 4 pin connector. This is ok for plugging into a mobo that supports it, but as for a fan controller like mine, which only has 3 pins, only some of the fan controller sockets were available as the extra pin on the connector got in the way of the capacitors on the controller. - Just something to bare in mind.
