Man of Honour
- 11 Dec 2002
- Darkest Norfolk
Bad DreXel, you know you need to have the oil cooler outside the bumper for a proper Jap Monster look
Bad DreXel, you know you need to have the oil cooler outside the bumper for a proper Jap Monster look![]()
Drag or street cars?
In answer to my earlier question about MOT failure, I imagine emissions might prove something of a stumbling block without 'connections'.
You're right, the air filter is in a bad position, but it was merely a case of that being the only place it will fit. Yes, if I could move the expansion tank it would fit nicely in that corner, the problem is there is nowhere for the expansion tank to go
I may look into getting a smaller expansion tank and sqeezing it in somewhere. Either way that probably won't be the filter's final position, but it will do to get me running for now.
The yanks don't even bother with a filter, they just run with a mesh over the turbo inlet........
It can't go downwards, below the filter is intercooler piping and the bell-housing.whats under the airfilter? couldnt it be routed down somehow?
Overlag said:also it looks small for a turbo setup...?
