I dont have any sort of fan controller at all ION, i was going to get one but i opted to get modular cables instead with the silent eagle fans. Got them running on standard at the moment and the rear fan that is sandwiched to the OEM rear fan is connected to the motherboard.
ION whats the tool called for removing the pins from the molex plugs and power connectors etc?
Thanks man, i worked pretty hard on this and i'm glad its paid off well :'D
With that done it was time to install the fans! NOW, i bought 2 fans today in hopes of replacing both the antec ones but as i found out when i looked inside the case the existing fan is wired into the fan control at the rear so i can't remove it completely! So i decided to mount 2 fans together, the old one and the new one and set the rear fan on medium to help the inner fan. Not sure if this even works or if its a good idea but i didnt want it to go to waste :').
Ah what i meant is u said u could remove the fan cause it was connected to a small fan control.
Removing pins can be a pain just depends on the connector some are easier than others. Main reason i do it would be it probably not going to help in the noise front likely to make a bit of turbalance.
post the pics of the lighting if you can please.
Im really liking the LEDs ties the build togeather i think. cant wait to see pics of it when you get the 5850.![]()
Well then just remove the old fan by getting that solder off and then simply strip ur new fan of its connector solder that and ur done. Mind u i have to say buying a good fan controller is always a good buy (T-Balancer is the best if u can afford it(but any manual one will do the job just as good)). Yea you can buy extension cables for pretty much every cable in ur pc then just release the pins from the connector and place the braid right over (to get a nice tight fit). Btw just so u know if u plan to braid any fan cables make sure u use 4mm braid at least cause anything lower is tight and just ends up killing ur fingers (then again i had to do over a metre of braiding for each cable and i individually did each wire seperatly apart from a few).
Thing is really though with ur case is cause its so clean and most of the cables are quite well hidden anyway. However wouldnt take u long as u've already done most of them might as well do the the atx 12v as thats really the only one noticeable apart from the fan cable at the top.
