Can not wait to see this when complete, Loved the aircube![]()
 Thank you.Looks really good Waynio, out of interest what do you use to mock up your sketches?
 Thanks mate, I use google sketchup nice & free & plenty good enough to design good stuff
.Update time
.Here's pictures of the edges after cutting & using the disc sander.
	Couple of action shots while I was doing the 240 grit, I found switching between these 2 grip styles kept my hands functional for longer.
	And the mess & result from many hours on 240 grit.
	Then did 600 grit, then 1200, could go & do the 2000 & polish but feel there is no need, now all thats left to do with these pieces is when I get the new drill press cut fan holes in all the big pieces, sand inside the hole & start sticking them all together with the clear acrylic adhesive, then that's all the hdd fan holders made, I'm going with light, dark, light, dark, light
	Holy sheet an entire day of wet sanding 6:30am to 6pm so I think I'll have no problem getting to sleep tonight, feel like I've been doing the twist dance all day lol
, but luckily they won't be seen thanks to the flat bar which covers the bottom area phew
, but the thought of drilling & tapping I figured it would look a tiny bit messy so went for the adhesive
