Wouldn't work as the bottom hdd screws in from the bottom mounts, anyway fixed them up good now & didn't have to touch no dirty adhesive
OK I stayed up all night so I could make some progress & managed to make some woo hoo
Filed a bevel on each of the fan holder pieces that come into contact with the fan blades because of having to slim the fan frames down by 0.5mm, these pieces still need a good bit of filing & sanding on them, then sticking together.
Then slimmed down all the bars to precise size & done another mock fit.
Then added the angle bars to the 2nd hdd cage so the hdd cages have turned out quite acceptable to be honest.
Marked up the bottom panel & 2nd panel for fixing the square bars to the 2nd panel, but first I tried doing the tapping with power drill thinking I've done it before & was ok, well the tap snapped first try lol, had to cut another piece & get it to precise size, switched to doing the tapping manual & very careful, did ok for 2 of them, then another one snapped, cheap taps, then another, then went to try a new tap & found it was the wrong pitch size so the screws didn't screw all the way in properly lol, so I'm left with a 2 legged panel until I can get a new tap which I just ordered a few, cheap taps again because they were the only ebay seller that offered express delivery, it's the only sure way to get deliveries on ebay at this time of year.
The ones I tapped successfully are very good, solid & perfectly in place wooooo
So not much done but any progress is progress + I'll have my sleep pattern fixed after today even if it is temporary
