Can only multi quote 3 at a time lol.
Evil^ Thanks mate
			nice build, makes me wish i paid attention to technical drawing in school
thread subscribed
, I had no engineering lessons at all, it's just been heaps of trial & error to get where I am now so if I can do it, anyone can
			Nice to see another update!
Honestly, you seem to pretty much have project logs down to a Q! Reasonably often updates, good explanation and a reasonable number of pictures!
Absolutely loving it
kd
Thanks kd, no other way to do a project log
 & it's good to share how things can be done so anyone can take bits of ideas & come up with their own stuff once they learn & understand the basics
			haha 11 tests, sound almost as much as a perfectionist as me
This is an interesting build, will keep my eye on it.
Best to test methods before trying to apply them
 & thanks mate
I tried doing these simple angle connections 3 times now & still not happy with the results & 1 more muck up & I'll run out of spare angle bar, I think it's the low grade of the aluminium sheet, when I tapped the bars which is a high grade quality the taps were perfect & strong, not so with the sheet So I'm going to skip trying to tap them again & use adhesive, I'll be sure to run some strength tests before I do though
.  I'll buy the adhesive tomorrow along with materials for making some jigs.
It kind of looks fairly acceptable but really it's gotta be better than how it is, a big part of the design is easy maintenance & if kept like this it could be a slight PITA maintenance
Also came across a sweet way of painting aluminium in Darth Beavis's new lan rig which I'll be doing & keep the metal visible like anodising & it's simply candy paint straight onto the aluminium & clear coated so this is what I'll be doing for finishing & can do a good colour coordination this way too
