Junk that POS aerial and get a lightweight one![]()
Why bother spending money, possibly leading to problems with the seal aroudn the aerial/reception.
£5 for parts and you can control it with a flick of a switch, plus as I was installing my new HU and putting in an ipod lead, it was just common sense to do it at the same time. Simples
80's aerial = awesome, mine doesn't go up/down when switching modes, only comes up when I turn the unit on.
You got a link to that switch installation, I wouldn't mind having control over it, would be handy when not listening to the radio
http://www.itr-dc2.com/forum/viewtopic.php?t=73427
More pics and info there
It was easy, just cut the blue wire on the conversion loom and put in a simple switch in there. Some spade connectors, heatshrink
and a soldering iron is all you need. Or just crimp the connectors if you can't/don't want to solder.
Really need to sort my suspension next after the gearbox rebuild. It's soo damn low that on a good blast around the countyside I have to slow right down for any dips or humps as it keeps bottoming out/wheels hitting the inner arch. Silly muppet to whoever put these springs on the car!!! Coily time
Glad she is ok though.
) but the car is going to WIM on Thursday for the castor bushes. I assume you have a press?
