- 1 Jun 2010
- Bedford
Wow 4 x Titans!!
That's some insane gfx horsepower
Looking goood.
However, I notice that you've got both of them at the bottom exhausting. That seems very inefficient, where is the air coming from? There's only one intake down there.
I would be inclined to create a "wind tunnel" sort of effect whereby one intakes and the other exhausts but keep the current intake there as well which should help out the temperatures of the rad on exhaust.
Kaap: I think it will probably be fine, I have a similar setup in my TJ07
Only way to know for sure is to try it, and change it if its no good, but its a royal PITA I know, all I can advise is don't "finish" the rig completely with everything tidied away and perfect until you are happy with the position of the rad/fan setup. That way its less annoyance if you have to turn them around.
I know with my quad gpu rig, I tried quite a few different ways and in the end almost went against logic but it worked.
Lots of people think that you should draw cool air into the case through the radiators but for me that didn't work for all the radiators, sometimes even warm air blowing out through a radiator is better than warming up the inside of the case. A lot depends on the ambient conditions where the thing is going to live and other factors, so if you can I would run it like you have it and if then the temps don't look good try it with one pulling in and one pushing out.
My way would mean that one rad is hotter than the other as it'll get the warm air exhausted from the first.
However, you will get some air at least and slightly cooler because of the single intake you have down there.
The other option i would advise, which it probably better:
Both rads are intake and the single fan is exhaust, but a fast one.
It also looks like you can mount a fan in the top of the rad compartment, maybe put one there exhausting into the main compartment?
Well, that's a kick in the nuts ay? lol
Is that just the one or all of them?
Tough break, hope you get things sorted![]()
Very nice
How do you feel after ripping apart £3500 of Gpu's?![]()
What a beast rig. Honestly, dont really like the case though... Either way, solid build!
