I cannot wait for the time to come when you post a vid of this thing in a finished state.
I keep thinking its getting closer but its still a while off yet.
Welding took nearly 2 weeks as they're mega busy but its all back now and put back together.
Subby mounts welded on, these buggers aren't moving!!
Headers all welded up nice
And the rest of the bits
So now the list is;
Rear plastics to trim to fit the frame
Rad to find/sort out and hoses to run
Oil cooler to mount and the lines to run
Find/make a sprocket cover and get hold of a slave cylinder. (These will be the same as the RF9 maybe?)
Sort out gear linkage
Look into a different shock linkage as I think the angle my dog bones are at could be a pain down the line
Carb to mount
Fuel pump to buy and mount
Wiring loom to make Rear light to find, CBR subby but not sure on the year!
Think that should keep me busy for a while!!
Oh, 6 pots arrived last week too!!
These are awesome on the GSXR and I found these fairly cheap.
