Got the EK block installed, looks lot nicer.
Have tidied up my hosing as far as practicable.
And took me a while to prime the systemm had the case in all sorts of positions!!! seems to be running well now with no air bubbles.
Just doing the leak test now, piccies to follow shortly.
One comment mind, it aint exactly quiet!!! It's not bad as an A-Weighted SPL, but there is a tonal component somewhere (I think PSU) that is doing my nut in. its probably around the 500Hz mark as a guess.
Also, the pumps are pretty noisy at their max flow setting. hopefully the tempes will let me run them at their minimum setting, as they are reasonably quiet then.
Obviously, proper noise level measurements are in the pipeline
