I'm sure from their tech speak, the label is part copper or something and helps with heat blah blah, don't remove, void warranty I believe
Took my sticker off. Screw the warranty.
Was supposed to be a budget build..
...turns round and drops £800 on just a cpu
Just out of curiousity how do you make your own distilled water, you make your own spirits at home?Good thing I can make my own Distilled water!
