Glad to hear you didn't kill it![]()
Killed it... hmm perhaps, although you could possibly fix it. Let me explain, even though I got the board to boot on my bench supply by giving it 12v - 0.1amps and running some wires to effectively bypass the stepper motor drivers, it wont boot under a normal supply and hangs. So I decided to get the multimeter out and trace the fault on the board. It didnt take long! there was grounds across components all around one particular driver, this is the result, I took the driver next to it off for comparison:
If you look closer you can see ive scraped the board to find the traces:
The bottom left two missing traces are 12v and ground, the pin next to that is also cut and I think it's a data pin of some description. With all of the shorts removed the board now boots under a proper power supply. I could possibly fix it but it's clearly junk and the Geetech GT2560 I have ordered is far superior, because it is based on an arduino / Ramps mix up the drivers are slot in so if one goes it's an easy plug in replacement.
If anybody in here really wants me to attempt to repair that I will but im thinking it's better just to wait for the new board etc to get here. I might have to transplant the board into the current printer to print some bits for the new design but to be honest in my buying frenzy and not listed above I also bought a ramps 1.4 board and a mega 2560 so perhaps wack those in this printer and build the new one on the geeetech.
This has prompted an investigation and action to be taken. I have therefore invested in some DRV8825 Driver boards as well. These boards can step 1/32 rather than 1/16 which I read makes some of the axis more stable. 8 quid for 5 it's hardly a bank breaker!
