- 28 Apr 2007
So..... Can you do the benchies now
knowledge123 said:I can!but not 3dmark 06, doesn't load for some reason
futuremark Faq said:Q: I just bought the ATI Radeon HD 2900XT and 3DMark06 freezes during the splash-screen. What is wrong and how can I fix this?
A: This is a known issue and we have been able to reproduce it in our test lab. The problem lays in an DLL which we use to detect the graphics cards' core and memory speeds. We are working on an update to correct this issue after which all Futuremark benchmarks should run fine with the latest offerings from all IHV's. Until then you can work around this issue either by renaming the "Direcpll.dll" file (found in %WINDIR%\system32\Futuremark\MSC\) to something else, or you can run the benchmark using the -nosysteminfo command line. Please note that if you use the -nosysteminfo command line, you will not be able to publish the result online. Futuremark will inform all its users when the update is available!
Squakingcow said:Oh, hang on.... *finds how to fix*
W00t, got it=D
knowledge123 said:Here we are:
all settings default, this is on an e6600 @ stock, 2900xt (8.38 rc7 drivers), 2gb 6400 geil ultra low latency ram, asus p5b and win xp home 32 bit.
9616 3d marks
4236 sm2.0
4790 sm3.0
cpu 2093
willhub said:Tomb Raider Legends had better graphics than this :\.
