Caporegime
- 18 Oct 2002
Leaks suggest about 5% above 390X performance, i think that much is probably true.
A bit faster than the 390X (Which is no slouch) for £50 less and half the power; its not bad actually, if it overclocks like the leaks suggest its pretty awesome.
Leaks suggest significantly faster than the 390x, which is what I suspect. I think DX12 performance will improve considerably and also... this is AMD. Performance won't be the same for 6 months then drop off as some refreshed part with slightly higher clocks are prepared, performance will improve significantly.
What is 30% faster than a 390x at launch will be 50% faster before the end of the year probably.
The RX480 looks really good, but after being told about the RX480, a bunch of people pushed the idea that it sucked and as it was only 90W(made up) there had to be a faster core sitting at a higher price point that would be epic. Now that that made up card doesn't exist people are acting like they are left with the **** slower card, rather than thinking, RX 480 is probably the fast card you wanted in the first place and that early leaks are with immature drivers(not compared to 6 months but compared to a launch), early bioses and NDA sneaky lower clocks.
I would put money on there being some situations the RX480 doesn't beat a 390x noticeably, in the same way some times a 980 is absurdly close to a 980ti when it really shouldn't be, but in many situations the RX 480 is going to be significantly faster than a 390x.
