Yup we will and you've clearly made up your mind. The issue you have is that if it does match 970 you'll think it's a failure, whereas I wouldn't. £200 approx for a lower power, less temps and better heat output would be a winner in my books.
It would be disappointing as the specs don't match it only being 970 .....clocked at 1266 its 5.8 TFLOP card - which means it should easily match 390X/980 stock......
spenty of evidence shows it does - even on dodgy drivers - its showing it is very close to that and that's just in DX 11 benches; it will be faster in DX 12.... I've even stated it will get even faster with driver improvements......this is just logic; as AMD never had regression in performance in their graphic chips...
where it falls with OC is the real question......we just don't know
