It'll be months yet before the drivers are sorted, look how long it took them to get the Fury X past the 980, by the time the 480s finally away from the 970, the 11 series cards will be here, so no one will care![]()
Are there any specs out on how loud the cooler is?
Thanks
So the earliest I could get one delivered, would be Thursday unless I pop into the shop?
do amd have anything like geforce experience to optimise for games?
I'm a bit confused... is the R480 released tomorrow, or is it the announcement?
If it is being released tomorrow, then urm how do we get it delivered for release day when there is no where that even has it up for pre-order, or the UK price is not known.
two of my friends said the exact same thing lol, Guess that £20 makes a big difference
Just because there's a lot of empty air doesn't make it a bad cooler. The more you tighten up the casing, the hotter the temps inside would get. And unlike open air coolers, a blower cooler needs to have a deep-sitting fan with much wider blades sitting past the processor and heatsink, so a bit of length is inevitable.The cooler is mostly empty except for the spinning bit and a small-medium black of alu with some fins. Rest is just empty. Bad cooler design for sure, could have had more metal in like some heatpipes or more alu with fins along the card instead of just over the gpu part. If its not going to clock much i bet they could have got away with a smaller cooler for similar cooling ability. I think the cooler they have (if performance and cooling is to be believed at leaks) is to make it look better than it really was.
There is a Profile option in the AMD Radeon software where you can configure games etc to get the best out of them, if that is what you mean?
280 including shipping and 3% vat 270 with free shipping
thanks it is, i'm lazy and don't tend to mess with settings but the nvidia geforce experience supplies the optimal settings for your gpu so was hoping amd had the same kind of thing specific to your card
Is that urine color scheme standard?You probably never saw it as I re-edited my post but there is a screenshot of it:
There is no free shipping to Ireland.....
Take a £218, add my 3%, add shipping and this is what I pay.
