If anything 4GB is easier on the memory controller! No idea why the memory is clocked lower on the 4GB models :/
It might be cheaper RAM modules??
Imo most titles going into 2017 will support DX12.
No its just using slower Ram speeds for some reason. It was explained somwhere in this thread. I think it was to give the 8gb version more performance.
Yea it is just lower clocks.
Any more info about these 480s frying cheap motherboards by drawing too much current from the PCI-e slot?
Blown out of proportion I expect, as AMD would know the implications of selling an out of spec Pci-e card.
Until others come back with similar tests, it could be a mistake with their testing methodology (not making excuses, just needs confirming)
So can anyone give me a list of 2016/2017 games that support DX12
It could be a bit GTX 970
Simply going from 4gb to 8gb should make no difference to the bandwidth.
You must have missed my post where I did say I waiting for AIB GPUs before making the choice.
I don't buy reference designs.
Your point is?![]()
I can think of a few cards that could blow up a poor mother board but the RX 480 is not one of them.
They are using slower chips on the 4GB cards, although apparent most 4GB cards have 8GB, just AMD turned off the extra 4GB in BIOS.
Seems like AMD really wont be selling the 4GB cards for long,
They must have some pretty poor RAM to get rid of if it is clocked lower than the 8gb versions.![]()
7GB/s is fast enough for the market this card is aimed at.
Adding the 8pin would have given the game away on the disastrous power consumption.
PR decision?
The RX480 4GB was around £175 today,so not sure how £35 cheaper after a 21% stronger pound in 2014,is that bad.
So,£35 cheaper than the GTX970,but as you know the exchange rate in September 2014 was $1.62 to a pound:
http://www.exchangerates.org.uk/GBP-USD-30_09_2014-exchange-rate-history.html
ATM,it is $1.34 to a pound:
http://www.exchangerates.org.uk/Pounds-to-Dollars-currency-conversion-page.html
That is a 21% difference from when the GTX970 was launched in September 2014.
OFC,typical AMD launch timing!!![]()
Most of the new games with support DirectX12, however it will probably be a half-assed support of it, as developers are still mainly focusing on DirectX11 and it seems that depending on the optimization and a-sync, games work very differently on AMD and Nvidia. The real world example: AMD wins on Ashes of the Singularity and Hitman and they win by 10fps+, while Rise of the Tomb Raider has an excellent performance on nVidia, but not AMD, for some weird reason.
